Aftermarket charger
johnnyshinta
2,666
22
I bought an extra wall charger and it feel noticeably different when plugging it in. The stock one is smooth and gives little resistance. The aftermarket gives resistance.
Can I hurt my phone with the aftermarket or is it normal.
USB is pretty standard, it's possible the new charger simply has some extra teeth so to speak which grab the outside contact area better....rest assured your phone will be fine.
by resistance do u just mean its a bit stiffer to put in and out? shouldnt be a problem mate. just dont pull on the cable to get it out lol :)
my stock charger dudes in and out very easily.to easily I'm my opinion but it's fine. I think you're good
I avoid issues and questions by buying only OEM accessories.
Sent From My Samsung Galaxy S III Handheld Device
my included earbuds ase really hard to remove and it hasnt got any easier after 3mmnnths
I travel a lot and have 3 - 4 chargers I use, including one in the car. I never have an issue. They are all fairly standard. The voltage may be different, which will effect charging time, that's it.
Abdullasteki
