all my calls are going to voicemail!! help!
momsescape
I am not sure what I have done, but my phone no longer rings, all calls go immediately to voicemail. and when I click on the right button where it used to let me chose airplane mode, silent, etc it just says phone options. Does anyone have any suggestions on how to fix this?
Thanks so much!
Jenn
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Re: all my calls are going to voicemail!! help!!
This may sound silly but have you rebooted the device? Do a battery pull and try a reboot and see what happens...
dtm_stretch
Awesome Possum
Oct 24, 2010
722
151
Thanks so much!
Jenn
Have you tried pulling the battery and restarting it? Also are you running stock or rooted?
*You got me this time Paul ;)
momsescape
I have pulled the battery, and I am running stock. the only app I have added is a task killer and I uninstalled that.....I am not sure what I could have done to loose the phone options on the side power button too.....wondering if i should try a factory restore??
dtm_stretch
Awesome Possum
Oct 24, 2010
722
151
That would be my recommendation. Just be aware you are going to lose all your data
revinger
10
I have had my thundwrbolt go into that mode twice, borh were my fault though and also couldnt plqce calls. I had putbthe phone into evdo only mode. Let me lock to 3g and do data, but had the unwanted side effect od not allowing voice calls.
Sent from my ADR6400L using Tapatalk
Devtodi
479
15
Sounds like you signed up fo google voice which was a big mistake. If that is the case, you need to talk to Sprint and they can disable it.
alestin
8
Are you using Sprint Airave device by any chance? Sometimes phones in airave coverage will not ring and all calls go straight to voicemail...
werkx
580
42
28
i get that when i'm in bad reception area. it could have something to do with your radio if you are not in a bad area. usually a reboot resets the radio.
Daniel Goldszmidt
This is what happened to me.
I connected my cell to my pc through a bluetooth connection.
Then every incoming call got immediately connected to the loudspeakers , after just one ring.
Check it up.
