Allow remote Lock and erase?
Yathani
166
For some reason, I can't activate android device manager under administration when i want to turn the "allow remote Lock and erase".
I have N910C running the second Poland lollipop release.
Any info is greatly appreciated.
Re: allow remote Lock and erase
Are you saying that you go to Settings>Security>Device Administrators​, try to check Android Device Manager, but aren't allowed to do so?
Pretty much what you said. It's there however when i click to activate it just goes back to the previous screen unchecked.
Are any other Device Administrators listed and checked?
Yes,
My email exchange which i removed because i thought it's the one causing the issue but that didnt help.
For now what i have are
- Tasker
- Greenify
- android device manager
Just for the heck of it, uncheck them, and see if the problem persists.
That didn't help unfortunately. I unchecked all and restarted the phone too!
I'm thinking it might has to do with the second lollipop firmware
Hmm, see what happens if you go to Settings>Security​ and tap Clear Credentials.
Clear Credentials is grayed out can't click it. I did reboot into safe mod as well but still no luck.
I think i will factory reset and see what happen.
That sounds like the logical next step. Hope it works!
Hello, I am having the same problem on my Samsung Galaxy s4. I really need to enable it, but it wont. And i dont want to do my phone reset, because i will lose all my data and games. please help!
Sorry for my bad english..
Thanks
stantn
