Am i using wifi or not?
Lurch81#AC
394
11
Ok i know this is probly a dumb question but i turn wifi on connect to my home network and the wifi signal shows up but how do i know if i am using wifi or verizon's network? its not like when you turn wifi on 3g goes away.
If the wifi signal bar is up with your other status icons
Just make sure it doesn't have a question-mark next to it
As long as you have that wifi icon up there working, then you are utilizing that instead of the Verizon data network.
Yupp. As long as you have the little wifi indicator up there, you should be connected to that.
quillo
