Android 10 Chinese head unit problem
Rumboo
Hi
I have a Chinese 10"head unit. The problem is when I start to drive the screen goes black and it stays that way until I turn it off then back on.All other senses are working, its got me stuffed, any held would be appreciated
Welcome to Android Central! Did you already try a factory reset?
These no-name/off-brand devices direct from China are almost always low quality, so there's a good chance it's just failing hardware.:-\
I had this problem in my Vauxhall unit, I took it apart and put it back together and it’s been perfect since. It started doing it the more I used my heaters and then stayed black.
Hope this helps
Hope this helps
Im going help u in the other thread u created dont want have parallel discussion
probang
