Android 4.4.2 KitKat: Battery Display Meter Problem
Sajjad Abdullah
I have bought a new android 4.4.2 KitKat mobile phone. It is QMobile Noir i7. Problem is that, I charge it to 100%. Then I start using it. I use internet, play games, call, text (all activities). But its battery display meter continues to show 99% or 100% (even almost after 6 or 7 hours). If I power off it, remove battery, put it again and then start it, then the battery meter shows actual battery level (like for example, 30% or 20%). If I don't do this, then it continues to show 99%, then suddenly alarms me low battery, when it remains only 15% (Or sometimes, it even don't do this and suddenly power off without any warning).
Any solutions?
It's faulty, so you could return it. Alternatively, a Cache Partition wipe may help, or you could try installing a third-party battery metering app.
Re: Why is my Android 4.4.2 KitKat battery draining so quickly?
It Depend On Your Charger If YOur Phone Is Full Then Quickly Remvo The Charger ... And Then Check ..Same Time YOur Phone On Charging And YOu Dont Remvo it So Your Phone Bettrey Is Stuck There So U Can Remvo YOur Charger If Your Phone Is Full Now
KidColoringPage
