My car has android auto, Bluetooth and cigarettes charging port. I recently purchased a note 9 which comes with non removable battery. Previously was on note 3 with removable battery.
Which kind of setup is more kind to my phone battery?
1. Android auto via car USB cable and display at the car head unit (resistive touch screen).
Or
2. Direct from the phone through the cigarette charger. I have a mounting mechanism for just the phone. Sound via car speaker using Bluetooth. Phone display will be used
Both will turn on gps and Bluetooth on. The only difference I see is the android auto method charges the phone slower compared to using direct cigarette connection. The android auto also turns off the phone screen..
I am planning to use waze and Google music at the same time.
Or
