Android Studio Update after project create problem
Arpan
hii,
Android studio after update Android Studio Ladybug then I am facing a problem build A build operation failed. Could not move temporary workspace (C:\Users\.gradle\caches\8.9\transforms\9d6f98967ac2ac9038e252040568c5d3-a9baa385-f6c6-43f7-9f47-5c482a7390c7) .
We Are try :
1. Clear Gradle Cache
Corruption in the Gradle cache can cause this error. Deleting the cache will force Gradle to re-download dependencies and reprocess any corrupted files.
The error you're encountering — "Could not move temporary workspace" — is a known issue that can occur after updating Android Studio (especially after an update like Android Studio Ladybug). This issue typically happens due to file permissions, Gradle cache corruption, or locked files.
Let’s go through a series of steps to help you resolve it:
Steps:
  1. Close Android Studio.
  2. Navigate to the Gradle cache directory:
    makefile
    Copy code
    C:\Users\<YourUsername>\.gradle\caches\
  3. Delete the entire contents of the caches folder. This will delete the cache, including intermediate build files that might have gotten corrupted.
  4. Reopen Android Studioand sync your project again:
    • Go to File > Sync Project with Gradle Files.
Why it helps: This forces Gradle to re-download all dependencies and rebuild its internal cache, which can fix any issues related to corrupted files.
2. Run Android Studio as Administrator
Sometimes, the error occurs because Gradle doesn't have permission to modify or move files within certain directories.
Steps:
  2. Right-click the Android Studio shortcut and select Run as Administrator.
  3. Rebuild your project in Android Studio.
  4. Check for File Path Length Issues
    Windows has a path length limit (260 characters by default). If your project or any of its dependencies has a path length greater than that, it can cause issues with file operations.
But not solve this problem
Welcome to Android Central! I moved this to the Software Development forum for more specific traffic.
cinemacritic
