Android System eating up majority of battery
sstephen17
305
Installed GSM a few weeks ago after noticing considerable drain on my battery (especially when I send/receive a lot of texts). Noticed that Android takes up a big chunk of the battery. Wondering if this is normal? I've done a factory reset and wipe my cache a few times a week.
uploadfromtaptalk1436847957412.jpg same issue with me this is driving me nuts and its only when im on wifi. uploadfromtaptalk1436848028387.jpg
Sent from my Awesome Note Quatro
I've never really fully understood all of this "stats" and whatnot. Here's mine:
Both of these battery stats indicate really really consistently poor cell signal. Those orange and yellow bars are draining your battery.
I turn off mobile data once im using wifi
Sent from the mighty Tab S
Which "category" if any, would MMS messages fall under? That is definitely my biggest battery drain. Even with a strong network signal (at home or work I'm usually at two or more bars 4G) and WiFi, if I get a bunch of MMS messages (>25 an hour), my battery literally drains 1% every five minutes.
will3208
