Android System
angiejones720
5
I charged my Moto E4 Plus the other day. Within the day, the battery totally drained. I charged my phone again last night and this evening I checked, and it's down to 47%. That's unusual, because I don't use this phone much, and I usually get at least a couple of days out of it. I looked at the battery stats, and Android System was at the top and it's using 17% of my battery. I've wiped the cache partition. Will that make any difference, or will I have to do a factory reset? Hope you can help! 🙁
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
nafizahp3
