Anker 4400 mah Extended battery thoughts
I've bought 2 different brands of extended batteries. The first was some no-name brand and sucked the second one offered about 5 hours more juice but sorta lacked what I expected. I came from a RAZR Maxx which had astounding battery life!
Sent from my SCH-I535 using Android Central Forums
I bought that brand only smaller size and I have had them for over 6 months with great experience. I had the same thoughts that since it was cheap it would be a dude, but they perform very well.
Like so much fonzy
i bought an Gorilla Gadgets 4500 mah with NFC chip for my S3 for 22.00 plus 3.00 shipping with a back cover and im getting outrageous battery life with it . I got 1 day and 6 hours with over 6 hours screen time just on the first day !! man its just awesome . Check out their batteries for sure . GorillaGadgets.com i believe is the site.
Also this battery blows away the 4300 Yesso battery i bought with no NFC chip
Not the 4400, but I got the 5600. Anker makes good equipment.
--Tapatalk on SGS3.
I bought that exact set up and I'm happy. The case is good, but very tight. You will think it doesn't fit, but you gotta work it. It's definitely thicker and heavier, but it hasn't bothered me THAT much after a few weeks use. You could always keep 2 stock batts and buy a 1000 mah power pack.....I might do that eventually. I will wait and see, but batt life wise...I am happy. :cool:
minnakoukka
