Any fix for the double click and vibration bug when typing?
alexcolka
187
I love SwiftKey, since app gone free that bug came along too, I know I'm not alone, there are at least 3 updates and still nada, is there a fix that really works?
Thanks,
Sent from my GT-I9500 using Tapatalk
Mine it's working fine and never heard of that bug. Try clearing the cache for SwiftKey in settings - apps.
Already done but thanks for sharing. Perhaps the only solution would be turn off keyboard sound and vibration and type to a sterile keyboard with no feedback :-(
Not sure what you mean by double click but my vibration has been on and off for the past couple releases. I've noticed that it only happens while swyping. If you use direct "peck" input then it seems to vibrate every time. Otherwise it stops and starts when it wants.
It's like an echo, the one click sound just sounds twice but fast giving an uncomfortable feel, same applies to the vibration feedback.
postald
