any recommendation for Pixel 2 wall charger?
I'm using the supplied Google rapid charger at home for overnight and a older Samsung quick charger at work for top offs. Seems great for now but I might switch the 2 and use the rapid charger at work.
I have the Verizon 2XL. I bought a Verizon branded charger just last week. It works almost as good as the OEM charger.
I keep the OEM charger at home, and keep the Verizon charger in my breifcase.
You can order the charger from Google directly, but not really cheap. For overnight charging you can use almost any charging brick with a USB A to C cable. You don't need Quick-charge. I like Anker and Aukey for bricks and cables.
CTS2158
