Any tips for battery drain?
mikeyboy80
248
Just installed lollipop and done a master reset on my new phone but noticed the battery drained seems a little fast.
Is there anything I can do in order to stop this fast drain?
I read somewhere that I need to remove any apps I don't use maybe?
Let the update "settle in" for about a week. Then see if the battery life improves.
Try to never let the battery get below 40% before recharging.
Removing apps that aren't actually running frees up storage space, but it has no effect on battery life. There's some data in every byte of storage - whether it's an app or random data has no effect on the battery. If you want to keep apps from running, use apps like AutoStart - No root to keep apps from running on startup and Greenify to keep apps from running on their own. (Don't Greenify apps you want running on their own - like Phone or your texting or email apps - or you'll never get phone calls, and you'll only get texts and emails when you run the apps. Timers too - they have to run on their own.)
Hi - I've noticed that my battery drain is MUCH quicker since upgrading to lollipop. (I think about two weeks ago)
Should I do a factory reset?
I've been reading up on RAM etc after above & other posts - should I uninstall all my clean master and one tap boost apps as they might actually be making the issue worse? I had over heating cpu yesterday for first time ever.
Sony has a section for shaming apps using a lot of battery under 4.4.4, is that still there after the lollipop update?
Mrhord
