Any way after 7.1.1 to enable battery %
milehigherik
660
Just like the title says. After the update you can no longer access system UI. This is pertaining to the percentage in the notification bar.
You should be able to access it. Hold down on the gear at the top right for a few seconds and then let go.. it'll bring it back. As you can see I have it.
Not sure what you mean. I never lost system ui tuner and never lost my battery percentage
I have tried holding down the settings gear and nothing happens. I'm trying to enable the battery percentage in the notification bar. After 7.1.1 I can't access system UI to enable that feature.
Interesting. I hadn't noticed that the System User Interface had vanished from my settings, but by golly it was gone! I had to re-enable it by holding down the gear, etc. Had to do it a couple of times before it worked, but it's back now.
MercedeZ
