Any way to turn off location sound?
jkrc717
Active member
Sep 5, 2013
34
I have the Note 3 from Verizon. It searches for my location wayyyyy too often. The sound it makes when it finds the location is so annoying and inconvenient at times. I cannot find an option to turn it off. I do not want to turn off location becuz of the weather and gps apps.
Thanks.
I use Tasker (same phone) to turn GPS on and off as needed (for instance, when Maps is the foreground app). Weather? Unless you're traveling long distances, it's not going to change much from one end of town to the other, so you don't need location services. (Just put in your location manually when you install a new weather app and that's the weather you'll get no matter where you are. If you're traveling for a short time, turn GPS on manually.)
fabumix
