Anybody not having problems with ics
The Sprint store employee I tried to get to fix my S II had no problems with ICS on his personal S II, but his was a rom...
Sent from my SPH-D710 using Android Central Forums
Just recently flashed CM9 A6 and have no problems whatsoever, but before that I was running stock ICS (installed manually) and no problems at all either.
Sent from my Samsung E4GT running CM9 Alpha 6 FG31
No problems here
I had problems with battery and when trying to tap on something in the browser it would go to another link. Say I clicked on a link to view a thread it would go to a fee threads up. That was the OTA. If you flash one of the cm9 nightlies you shouldn't have any issues.
Nothing here. Everything stock anf battery is roughly a day and a half with no problems on drainage. Wifi signal is pretty bad though. Sitting right next to my router and only 2 bars.
Since the ota update I haven't had any problems and battery life is getting better and better
Stock, unrooted, ota ICS finally working good for me after solving battery drain problems. I've seen some complaining about bluetooth problems but I don't ever use it so I don't know.
xtn
Hi, how do I set WiFi to sleep with the phone? Also, any disadvantages? Thanks?
Go to settings and select WiFi and press the far left hard button whatever it is called it brings up the settings then go to advanced which is the only option. I turned off network notification and set keep WiFi on during sleep to only when plugged in or never.
Reactions: sammad
Perfect, thanks GiantJay!
I forced it on my wife and sons on Sprint and no problems.
Sent from my MB855 using Android Central Forums
theantithesis
