What do you mean by 'fast charging problem' exactly? If you're using a different cable, that might be the problem. I've used mine with a longer cable and I have to plug it in and out a couple times for it to recognize the Fast Charging (otherwise it just uses 'normal' charging), but if I used the supplied cable, I have no issues.
