Anyone have WiFi connection issues?
anon(10221500)
84
I'm having lots of drops and weak connection problems.
Before you say anything about the router - I've had absolutely ZERO issues the last 2+ years with my G4.
I've had phones with wonky connection problems before.
I'm liking everything else about this phone so far but the WiFi problem is going to drive me nuts.
Any input would be appreciated. Thx
Sorry, I'm going to say that, my router also has had zero problems, but it does get loaded up on a fairly regular basis, and what you're seeing is what I see when it does it. Reboot and all is good again. Just sayin :)
00% sure that won't help.
Okay, I won't expect an attaboy then :) You might install a wifi analyzer, I've found mine helpful at times to find problem areas around the house. You getting trampled by a neighbor? We just have so little control over wifi, and BT for that matter, on phones vs a PC that you can take apart and fix.
OK - so you don't think it's the phone itself?? I'm no expert but I'm guessing all phones are not the same as far as connectivity.
Can't rule that out yet, I just like to eliminate everything I have some control over first. And you are correct, phones are not created equal, but you might just have a bad one. Why I like using an analyzer, if the signal is great but the phone still sucks, well. Sorry, these problems are really hard to second guess, just a matter of working thru all the options. I know it's hard to wait, but lets see if some of your fellow phone users chime in with their experiences.
I have had zero problems with wi-fi, and until I get a new SIM card tomorrow, that is all I have used. If all your other devices connect fine you may have a defective G6.
BennyHuyghe
