Anyone having problems setting up WIFI
CSI Guy
575
4
Anyone having problems setting up WIFI? When I went to set up my Tab with my home WIFI the screen that tells you to enter your password is grayed out. I can enter the password but the connect button is grayed out. Any suggestions. VZ did not know, and Samsung is closed.
OK Skatedawg you were right. I am using AT&T Uverse for my internet and their security type is not supported by the Tab. Samsung told me to call AT&T and get them to change my security type to WEP and it will work fine. Will let everyone know how or if this is possible with AT&T.
Called AT&T and they changed my security to WEP and all is well now.
