Anyone using a case with the 2000mah Battery?
PAC757
Trusted Member
Mar 1, 2011
875
Hi is anyone using or find a case that fits with the Samsung extended battery and back door? Someone mentioned to just buy a case for the Verizon model, don't know if that's correct or not.Thanks.
Most TPU cases should work. The SGP Neo Hybrid works. The Ringke Slim LTE Verizon version also works with the i9250 + extended battery. The ringke is highly recommended by many and I'm using it now with my own i9250 and OEM 2000mah battery
I'm HOPING (but honestly rather doubting) that my Otterbox Commuter will still fit once my 2000mAh batt and cover come. Anyone else using the Commuter with the 2000mAh? If not I'll have to get a TPU I guess
I got my 2000 mAh battery today and it still fits the Otterbox Commuter case I have.
No issues here with the TPU case fitting with the Samsung OEM 2000 mAh battery and case
on the kraken, do you need to use the hard shell portion to use the belt clip? also, how much bulk/weight does it add to it?
Yes you have to use the hard case. It adds a bit of bulk. Similar to ottetbox defender. BUT for me I love the hard shell outside rather then the rubber that sticks to everything.
isaackse
