Anyone using a Nokia DT-910 Qi Wireless Charger?
curney
335
13
I am thinking about the Nokia DT-910 charger since it holds the phone upright. I just wanted to make sure the coils line up for the S5. Anyone using this charger? I cant find anything when I google it with "S5"2013-02-02 12.08.48.jpg
thanks!
Curney
I haven't used the DT910, but I did try the DT900. It didn't work very well. It kept dropping the charge and reconnecting.
I have 2 DT900 transmitters and haven't had a problem with charging my S5 using a wafer thin, on battery receiver, with either of two different Spigen cases. I also have a RavPower wcn7 transmitter that I use, also with no problems.
I guess I was mostly wondering if the coils would meed up with the S5 in the right place. You would think so because the lumias and the s5 are about the same size.
Sahel
