Anyone Using Light Flow?
jus2sho
Active member
Sep 17, 2011
29
The LED indicator doesn't seem to be working at all with the Light Flow app. Is anyone else having the same issues?
That would be a shame... I just started using it on my note2 and I love it (the app, not the phone)
It's working for me, though I only have it set for the calendar, gmail, and Hangouts since those are the only ones that matter to me for having the LED notification.
Did you check the box under Settings>Security>Notification access to give Light Flow the ability to read notifications?
RichardDixon
