Anyway to stop/reduce this horrendous battery drain?
Lecrae116
771
Google services has been reported in use since my phone has been unplugged. Wifi and bluetooth scanning is OFF.
You show 6 hrs on battery with nearly 3 being screen time. The software is telling you that you're going to get about 7hrs sot. If you have other days with lower than 50 % of sot, check it out again before worrying.
Your cell signal strength looks pretty bad at the time of that screenshot. If that's how it is during the battery drain periods, then it's likely due to that.
