- Apr 17, 2012
- 19
- 0
- 0
I've flashed AOKP jb build 5 twice on my gnex and each time voice input doesn't work. All I get is " Unfortunately Google voice has stopped working" and then app crashes. I've flashed back to CM10.1 after each attempt and the problem is gone. I've tried the included leankernel and franco r366 on each and the problem only occurs on Kang. Has anyone else had this problem and if so what if anything have you found out. I would really like to try AOKP for a while but want to keep the voice input. Thanks!
The same problem occurs on all apps that accept voice input. ie: google search says "Unfortunately Google search has stopped working" etc...
