Apn/lte help
FASTEDDIE427
5
I just switched from AT&T to metroPCS and i unlocked my htc first. I found a few versions of what the apn settings need to be, however I cannot get LTE. Am I screwed because its not a MetroPCS phone?
It has a 1700 band capability which is T-Mo's...It should work. Can't you get MetroPCS to help you out? They should be pretty eager to get it set up properly. Our you sure where you are at its available?
AndLesUK
