[APP]Smart Wall - Battery Wallpaper
mvysata
82
Check out my new app Smart Wall, live wallpaper with battery status, knock flashlight, fast app launcher and much more
https://play.google.com/store/apps/details?id=com.kuma.smartwall
Description
- Shows the battery status and temperature
- Different images for homescreen in potrait or landscape mode, useful for tablets
- Change the background color according to the battery with various effects (transition to red or black, color loss background)
- Quick launch applications by swipe from the bottom of the screen
- Fast flashlight on and off by knock on the home screen
- Solid color for background
Very good app! I think it would be a good idea to make the widget to show the estimated remaining time of the battery based of the use statistics of the last battery charges of the device.
Thank you. I'm glad that you like my app. Maybe I could try to invent an algorithm to measure the remaining time but the point is if you would not accrue power consumption by this application. Which usually makes these applications... :)
LisqPhill
