[APP] Wireless Chief - save power and mobile data
ftgg99
8
Another awesome app from Fahrbot
Wireless Chief is an application designed to control the wifi and data radios in your device, as well as many related functions like background data and autosync.
It can be used to save power or minimize data usage, and works either by reading the screen state, the battery state or on a completely custom schedule.
All data and sync options require root access. There is no other may to manipulate the radios.
Features:
- Turn features on or off depending on screen state
- Disable wifi if no known network is available
- Change wifi scan intervals and scan attempts
- Schedule autosync and background data
- Force autosync on wifi only
- Disable wireless radio features according to battery level
If you have any issues, please leave comments in this thread or better yet use the "Write to us" dialog in the application's settings.
Versions:
Locked: All wifi options are free
Unlocked: Full functionality
Market link:
https://market.android.com/details?id=fahrbot.apps.wirechief&feature=search_result
Screens:
