Apps using battery
can3gxw
Trusted Member
Nov 1, 2010
804
How can I see exactly what apps are using my battery? I went to sleep last night with 98% battery and woke up with about 84%. This after it was supposed to be dozing.
When I checked the battery stats, it showed "Apps 10%", then mobile data and wifi with insignificant amounts. How can I find out what apps were running, taking up that 10%? I was using Chrome before going to sleep, so maybe that was still running in the background overnight? I didn't close it..
But if that's the case, how can I see WHAT apps took that 10% so I can be sure that there's not some bad app update running...
On the main Settings>Battery screen, scroll down -- you should see the app list there. It sounds like you're looking on the screen that shows the graph -- that's one step too far.
dairfod
