Asus Zenfone 2 Problem After Update System
Welcome to Android Central! I assume it's stuck there? Is the circle still turning around? Was the update pushed over-the-air, or did you install it manually?
Wait for 2 to 3 mins on that screen, usually it takes longer than normal to boot every after update. Also whats ur internal flash memory, the bigger the longer. Another factor is apps installed other than the ones preloaded on your phone, the more apps the longer the boot process..
Posted via the Android Central App - ASUS Zenfone 2 Z551ML
RichardDixon
