ASUS ZenFone2 heating problems help me!!!!!!!
Farid Abedin
8
Dear All, My ZenFone2 4GB has serious heating issues. I used CPU thermometer app from play store.
Please help.
Hi Farid, welcome to the forums! Check in your battery stats if an app is taking an unusual high percentage. Maybe there's some app going wild.
How to do it.
Can you give the range of your ZenFone2 using the same app CPU thermometer from play store.
Note mine is ZenFone2 4GB with 2.3 Ghz
We recommend following troubleshooting methods in ZenUI app called ASUS Support under Apps>ASUS Support>Assistance>System>Device Overheat. If the issue cannot be resolved then possibly there is a hardware issue and may need to be sent in for warranty repair.
If you have any questions, concerns or would like warranty assistance, please feel free to contact me direct at cl-frank@asus.com. Please include a link to this review as a reference with your response.
Sincerely
ASUS_USA
nemismom
