[ATT] Problem getting "Charge Only" and "Mass Storage" options
russell1997
98
Just got the S3 yesterday. :) :)
I downloaded the S3 drivers from samsung and i enabled usb debugging.
When i plug in to usb, I either do not get the usb prompts at all or when i do i only get mtp or ptp options.
Whenever I do not get prompts i can get it back by trying the dock then going back to straight usb (no dock).
I have never been able to get a usb connection via the dock which is sad because it was $50 and now all i use it for is to get my usb back.
Any ideas how to get back the options for "Charge Only" and "Mass Storage"?
Re: [ATT] Problem getting "Charge Only" and "Mass Storage" option
As per my post in that thread you linked, I don't think that does anything.
Mass storage is not supported and I don't think XDA has a hack for it yet, but I bet they will.
So far charging my phone and using PTP/MTP has been fine...although the file transfers are rather slow.
I found it in some other discussions after searching for the solution for a week...
1) click on phone Icon and in the keypad enter *#9090# and select "Log via UART/USB"
go back and again go to keypad
2)enter *#7284# and select " MODEM" under UART and select "PDA" under USB.
3) Connect phone to the PC with USB cable.
Now Windows ask normal samsung drivers which install automatically!
That's all.
asnes
