Attention Verizon users... And maybe others
trucksmoveamerica#AC
Trusted Member
Jul 20, 2010
8,556
1,244
113
Little late, but do not forget to disable the following app, unless you like having apps installed on your phone that Verizon thinks you will like.
Go-to settings, apps, tap three dots on right top screen, select include system apps and then scroll down to this app and disable it.
This what At&t's icon looks like. And yes, disable it.
I do this on every new phone from Verizon, but thanks for the reminder as it has been a while since I bought a new one!
Is this the Tmobile version?
For those wondering, just checked my unlocked model on Verizon, and it doesn't have it. It better not be anyway but just had to verify to make sure inserting Verizon sim didn't install a bunch of crap
webdesigner
