Audio Applications
lsmunoz
290
7
How do you edit the list of audio applications that comes up after connecting wired headphones? By default it is coming up with music player (Sammy), video player, YouTube, Voice Recorder and Google Talk. I want to add Google Music, Pandora and TuneIn Radio.
Thanks
i think that list is a smart list based not only what you have installed but on what you use frequently...if you want those apps to show up you have to manually use them a number of times and they will climb up the list
thats how it is for sharing, so i dont expect it to be much different for apps
I thought that as well, but some of the apps I have never used and I use the apps I want daily. The "smart" list does not seem to be updating.
kudro
