- Aug 19, 2011
- 5
- 0
- 0
I'm a newbie to the droid world (have a Samsung Charge). I've tried my best to find a post on this issue for over an hour now but haven't found anything related. So if this is a common repeated post I apologize.
I've found that the audio quality from the handset on calls is SO BAD that quite often I find myself having to plug in my headset just to make out whatever the caller is saying. It sounds like they are talking through a sock! Mind you, I had tested this in the store prior to my purchasing the phone and didn't have this problem. I'm sure the issue is worse/better depending on the callers phone. Most of the time any LAN line (digital or analog) are the absolute worst.
Does anyone else have this issue? Are there any suggested fixes, downloads, apps, etc that are known to have fixed this problem or made it better ??
Thanks all!
Thanks all!
