audio clarity problems
Lou loa
24
I have had audio issues with my Verizon g2 during calls on speaker or not
if two people speak at the same time, the audio becomes garbled and cannot understand.
I truly believe it has something to do with the voice suppression.
during a call I press the setting button and try to turn off voice suppression, however I cannot the setting is light and will not allow me to turn it off. does anybody know how to turn off voice suppression.
love this phone please help ,thank you
Go in to your phone / dialer app, click on the settings, click on call settings, and scroll down to voice suppression and uncheck it.
Make sure you don't have OK Google turned on for any screen As well, it has been making calls impossible to be heard.
Sent from my VS980 4G using Tapatalk
If the audio is garbled on a CDMA carrier, I suspect it's more a weak signal issue than a voice suppression issue. Weak CDMA signals sound underwater. Very weak signals sound like gargling.
I had Verizon for a few months and always thought their call quality was terrible. T-Mobiles is fairly good, I hate to say it and I threw up a little in my month while typing it but Sprint's call quality was the best I ever had. Too bad their data network is horrible. I had them for 10 years and it was a very terrible time.
thank you for your help, the only way I can get to the voice suppression option is during a call I tap the Menu button however that option is lighter than the other options unable to turn on or off. the only time the voice suppression option comes up is during HD calling mode. truly believe this would fix my audio issues with my phone thank you again
No problem at all, I wish we could have figured out how to fix your issue.
Richie Q
