Audio issue
Davidwb0002
Audio cuts in and out while on phone calls, on music, videos, and over Bluetooth. I have a Pixel 7 pro. Android 15. Also happened on 14. I've factory reset the phone multiple times. No apps are bad. No one seems to know how to fix.
Welcome to Android Central! So you're on the Android 15 Beta? First, make sure you're sending feedback to Google about this, in case it's a bug in the Beta.
You mentioned that it also happened on 14 -- how long ago was that? Or did it start on the 15 beta, and then you reverted to 14, and it continued happening there?
Does it persist in Safe Mode?
A few months ago it started. Just updated to 15 beta maybe a week ago. Yes it still happens in safe mode. Also did the pixel diagnostic test and it was fine
MIght be a hardware fault. Have you tried a factory reset? Are you still on 15 beta? If so, try reverting back to 14 and see if it persists.
mathewsjamie138
