Audio issues?
mapexonly
99
12
After the ics update i noticed when i listen to music sometimes i get no sound and have to restart the phone. Any problems like this for anyone else? Any fixes?
Sent from my DROID RAZR MAXX using Tapatalk 2
Same thing was happening to me. Factory reset seems to have fixed it, but it's only been one day.
Sent from my DROID RAZR using Android Central Forums
I finally did the fr which always sucks but i did it. Seems fine at the moment hopefully that fixed it.
Sent from my DROID RAZR using Tapatalk 2
I had that same issue. I rebooted the phone, but i didn't have time to try it again before work. we'll see later. no factory reset here yet either.
I've been noticing that sometimes various sounds like notifications and dialer keypad tones will disappear. I don't have to reset, though--if i go to Settings->Sounds->Volumes, and move the volume sliders around, the sound comes back. Seems to be a bug with ICS, since it never happened with GB. Reminds me of Windows, where sometimes I'd lose sound, and would have to go into the Control Panel and mess around with the volume controls.
hakuntata
