Audio Issues?
Fish 0f Water
My audio randomly goes quiet with the 3.5 Jack. My bluetooth also randomly shuts itself off or disconnects from my car and watch. Anyone else having these issues or find a fix?
You love safe mode lol. Thats your first suggestion for everything. SAFE MODE.
Its first part of diagnosing a problem it eliminates and 3rd party applications giving issues . Also restart the phone also is a soft reset . These things are can help a lot when issues arise , and they are easy steps without replacing anything or sending in for repairs .
There has been issues since the android pie update and this being one of them. I have audio issues too I made a post about it that no one has answered yet. Hard resetting and safe mode aren't always the answers either.
Yes I know some are experiencing issues, I do know know a soft reset or safe mode dont fix everything but you have to start somewhere and those are most logical and easiest way to go about it. Then you can get into more complex things .
Yep, it's almost always a first step, since one of the most common causes of a problem will be a 3rd party app misbehaving.
It's fine for you to disagree, but this is a harmless first step, and you'd probably be surprised how often this has helped solve a problem on the forums. Good luck with your issue!
heritagevine07
