Audio Problem
jcuadra21
Hey guys, I gave up, coudn?t find a solution on google or anything. Lets see if you can help:
The audio of my phone is not working correctly when activating the "speaker" or connecting the Aux to listen to music. After some seconds later that the screen goes to sleep, the audio goes off as well. The call or the song that is playing continues, however, in the case of the call, i have to activate the speaker bottom again; in the case of the song, i have to unplug the aux cable several times to listen to the music again.
I am not sure if this is a hardware problem due to a hit or something.
I appreciate any help.
Welcome to Android Central :)
Has this been an issue only recently or has it been there for some time? Also, what Android version are you on?
Thank you,
Its been for some time, probably 2 months. I am currently using cyanogenMod 10.2.0
Have you tried to use another version of CM? Maybe 10.1? Just to see if it's a software or hardware issue
They seem to have a lot of bugs, even with stable builds
Let me see if I can find a fix for your specific version...
oval_clarity
