Audio Volume on 10+
onthehunt
200
6
18
Came from the Note 8, which has great call volume through the internal earpiece and speakerphone and excellent volume with audio playback from other apps. The 10+ speakerphone volume is noticeably not as loud as my Note 8, and the extra volume function icon is missing on the call screen. Also, a handful of apps have lower volume with audio playback. Anyone else experiencing this?
This may be due to your sound settings, Go to Accessibility > Hearing > Mono Audio > Set it to off
If the problem isn't this try going to Settings > Sounds and Vibrations > Sound Quality and Effects > Set equilizer to Nornal
If none of this works It may just be the phone speakers dogy or thats how all s10+ are
You might have something set wrong cause i have my Note9 here, my daughter has the Note8 i compared them next to my Note10 Plus and it out blasted the Note9 and Note8 sound.
Is there any way to actually test the earpiece on the note 10+. When I am on a call using the phone, getting the sound from the TOP of the phone most likely it seems VERY hard to hear the other party
