Auto connect to known WiFi network - Help please
Phoneguy108
759
Recently I noticed my phone will not auto connect to know WiFi networks unless I reboot the phone. It's on multiple WiFi networks as well, so I know it's not an issue isolated to one particular router. This is killing me as I am mistakenly using up my data when I have access to a WiFi network. I always just keep the WIFI turned on, and let it auto connect to known networks such as work, home, friend's WiFi etc.
So for example if I am connected to my house WiFi, leave the area and come back, the phone won't again connect to my WiFi until I reboot the phone. Once I reboot, the phone auto connects to my WiFi and stays connected with no issues
I'm finding a good amount of bugs with the phone and so far no resolution to any of the issues. Getting frustrated as the phone wasn't cheap
Any ideas? Thank you
never had that issue. mine auto connects everytime and my wifi goes to sleep a lot. everytime i pick it up it autoconnects. I don't have any suggestions on how to fix.
Thanks for the fast reply. I am trying to avoid a hard reset. Hoping 5.1 will come soon and eliminate some of the issues I'm running into.
I got a bunch of Apps I never updated. I'll start with that and hope that resolves some of my issues.
I have the same issue and all my apps are up to date. I just started noticing this was an issue this month. Could have been a problem before but I'm just noticing it.
It's still happening with my phone as well actually. It definitely subsided though after updating all my apps but it still fails to connect on occasion. Usually I notice it after using a ton of my data. Pisses me off.
Once I reboot my phone the WiFi connects with no problems
I've owned many android phones through the years and this one is by far the worst when it comes to Wifi. You shouldn't have to randomly reboot your phone to get the Wifi to connect on a $600+ device.
Amanda40
