Automating Bluetooth function when AC power detected?
SammySung100
3
I have the ICS VZW GN and was wondering if there's a way to make Bluetooth and or WiFi turn on automatically when it detects the AC power plugged up and charging.
My situation is that Id like to automatically have BT enable when I plug my phone up in the car, as the car is searching for the paired device, but then turn off BT when I unplug and leave the car.
Is this possible? Or do I have to keep doing this manually?
Thanks in advance Folks!
yes, Tasker from the play store will do this. it is a very powerful application so IMO it is totally worth the Price.
it can automate pretty much anything
for example: turn on Bluetooth when AC power and turn it off when AC us unplugged.
turn on wifi when you get to a certain location
put into silent mode based on certain calendar events
keep certain applications awake when plugged in
send customized text messages during certain times of the day if they text/call you (someone calls during the night, have it send a text saying "i am sleeping call you later" or something like that.)
Just TONS of stuff and it will definitely do what you are asking.
Reactions: SammySung100
yanis
