"Backup Lite" high battery and GPS usage?
yo0123yoyo
109
Today's the first day this has happened, the GPS icon is almost always showing on my status bar and causing it to use up my battery faster. Does anyone have this issue? What did you do?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,789
5,005
113
Is Backup Lite a preinstalled Samsung app? Can you find it in the App Manager and disable it?
LaTuFu
817
I'm not having any issues with battery drain by leaving GPS on 24/7 (a first for me on an Android phone, too).
What is Backup Lite? And why are you using it?
If you're using it to back up your apps, you're better off using your Google account for that. No additional battery drain going that route.
And HiFont? WTF does a Font pack need "high battery" use for anyway?
yo0123yoyo
109
When I go to press on Backup Lite there's not even an option to uninstall? I don't even know where I got that app from
LaTuFu
817
My guess is you enabled backup services with Samsung or your carrier during the initial setup process.
Can you turn it off?
yo0123yoyo
109
Got it, it was the Avast anti theft app that I installed when I got the phone. "Track device every 5 minutes was checked" much better now
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,789
5,005
113
Backup Lite is part of Avast? If so, then the Turn Off button may have been greyed out due to Device Administrator privileges. Glad you figured it out!
