Battery 100%
jaybro0813
235
6
I have had a few Android phones and there are certain tricks of the trade to get the battery to charge to 100%. For example there was something called a bump charge where you charge fully turn off the phone and charge some more and will charge further
Is there any trick for the bionic?
I take my phone off the charger and it goes to 99%. I understand the system is built to not allow to overcharge.
Any ideas forum buds?
I have never seen thecBionic report anything as a percentage that doesntvend on a zero
Except for 15 and 5
I've found that using my old blackberry charger gets it the few extra steps to show 100 and stay there for a bit.
Guys this is totally unnecessary. The battery indicator is just an estimated amount based on various things such as voltage and learned calibration. Using a different charger wont make a difference. Chargers are rated off the amperage they can deliver, which the oem charger will always have a sufficient rating. As batteries are nearing a full charge they are drawing the least amperage. You cannot "force" more charge in with a different charger.
Sent from my Transformer Prime TF201 using Tapatalk
Not to switch the topic much but i have a dock / spare battery charger i got off of Amazon (I've had one for my OG and X as well, i mod them for dock usb to computer and spare battery to outlet) and the spare battery won't charge past 90% no matter how long i leave it in there. My other spare batteries always completely charged this way, if I put it in the phone and plug in it well then continue to charge.
Sent from my DROID BIONIC using Tapatalk
That's funny...my battery says 100% and it's been off charge for an hour and a half.
freewarelab
