Battery Activity reset
allen7_75
6
Does anyone know how to reset the battery activity or how to diasable it from tracking how long much time you spend on each app. I have looked everywhere and can not a answer to this. Its a samsung s21 under software it says one UI version 6.1, android version 14. Thanks
Welcome to AC!
You referring to digital well-being?
Moved your question to the s21 forums
Welcome to AC!
Its under settings, battery. Then under battery usage it shows what percent each app used and how long it was on screen time. Im trying to figure how to delete this info.
Oh ok that's device care it resets when you charge it to 100 percent or have the 85 percent on
It only resets the one that says since last charge. There is also one that says today, if you click on that it shows the last 7 days of usage. It shows percentage used for each app and also the amount of time on each app for the last 7 days. Im trying to figure out to to clear this info, there doesnt seem to be a way to do that.
You can't clear last 7 days it does that automatically but you can see for that day or last charge
So there is no way too turn this off. Im just trying to figure out how to disable it so other people cant see how long or which apps I am using.
You can use an app but it cost a few dollars to disable it from sight
I'm surprised you let other people in your phone My phone like my wallet which is personal and sensitive information
noisey wife and kids lol. thanks i will look into app
Reactions: mustang7757
cbbella
