Battery case?
mled203
58
I know on Amazon there is a case that charges the phone. Has anyone found anything better?
I ordered one from Amazon.
I liked it but there is no front screen surround protection so if you lay it face down, there is nothing to keep it from getting damaged.
That was my only nitpick. Other than that, it was cool.
Just my $.02
Mav. :cool:
Sent with Apple's permission on my Galaxy Nexus.
How much bulk does it add to the phone? More or less than the seidio battery? Perhaps pics
No pics. I returned it.
Very slim. Just like any other case. It does add some length (obviously) with the battery portion.
I did like it, but it did not suit my evil purposes. ;)
Mav. :cool:
Less bulk than the extended battery? And did it work?
Doubt it considering the ext. battery goes in the phone and the charging case is a case...
Sent from my SCH-I535 using Tapatalk 2
Equal thickness when compared to each other.
The entire phone slips into the case and the micro USB plug at the bottom.
You hook up the plug to the bottom of the charger. It charges both at the same time.
If the phone needs some power, you hit the button and it charges right up.
Pretty slick, slick.
Mav. :cool:
Not a bad way to double your battery life without adding a lot of thickness. I'd make sure to read A LOT of reviews, because I could see a low quality device like this sucking hard!
shy_panther
