Battery Charger connection
jmw10
5
Has anyone else noticed that when the battery charger cable is attached to the phone it has a little wiggle room? Is that on purpose so if the cable gets hit it moves instead of coming ripping out of the phone? or is mine just loose and by loose i mean just a moves a little bit. I'm coming from an iPhone 3g so i'm use to the huge connectors those phones have.
james
mine was tight when i first got it, now it falls out at the slightest touch. i would like to fix this problem tho.
Mine also has a little wiggle room, but since mine never loses "connection" I dont mind. But if yours is losing connection when it wiggles, then thats anoter story...
Cable
Micro USB are designed so that the cable wears, not the socket. Change the cable and you should be good.
zhuangquiao1
