Battery charger for two batteries.
thirsy1258
378
17
Hello all looking for options on charging the battery since I have two currently. Vzw used to have an option but I dont see it anymore. Is there anything to charge the standard and external battery when not in phone
Ed Ke6bnl
Active member
Feb 23, 2012
31
Been looking at this for a while. Let us know how it goes.
Works fine charged an old battery from a very old cell phone and work great easy to use now charging the bat. for the galaxy nexus this time from the usb last time it was plugged into 110 volts.
light is red when it turns blue it is charged.
Ed Ke6bnl
Active member
Feb 23, 2012
31
I read some reviews that the pins move easily so they always have to be re adjusted, unless I was looking at a similar product.
they need to move to use for different batteries and you need to check and look down at the connection every time you charge a battery. If you want it for just one type maybe a dedicated charger is better for you. this one will work for 90% of all phone batteries and it take the extra steps to charge no biggy
offline050
