battery charges and..
Paskell
94
Over night had my phone plugged in I checked to make sure it started charging. When I awoke I unplugged it and I opened Instagram looked at some stuff for 2 main close it and locked my screen. Then my light flow light for low battery comes on.. Went from 100 to 15 percent in 2 minutes.. With is going on this is the second time this has happend
When you unplugged it in the morning, are you sure it was at 100%? It's possible the charging port or your cable is becoming faulty, or the connection is loose, so maybe the charging stopped soon after you plugged it in last night.
hooram95
